quick wheel fitment verification
Russ757
24 minutes ago, Russ757 said:
I think these will fit, but would like confirmation before hitting buy
2020 stock RST Crew. 275/60r20 stock suspension no leveling
VAPOR - D569 / BLACK W/DDT
6 LUG
D56920909850
  • WHEEL SPECS:
    • Size: 20x9
    • Bolt Pattern: 6X135 / 6x139.7
    • Offset: 1
    • Hub: 106.10
It would help if you'd post a picture but, with a 106 bore, that isn't a hub centric wheel. GM trucks don't like wheels that aren't hub centric. I wouldn't run it.
I've see them on  a few 1500s as this Pic shows.
https://www.customwheeloffset.com/wheel-offset-gallery/1690177/2020-chevrolet-silverado-1500-fuel-vapor-rough-country-leveling-kit
But when using online verifications say they work and some don't, so appreciate it.
That's a link showing them installed but as popular as they seem to be, I don't see many on 1500s
Edited by Russ757
OK apparently these won't fit but pn D56920909849 will. Only difference is +1mm offset
But here's the specs guaranteed to fit
  • Diameter: 20
  • Width: 9
  • Lug Count: 6
  • Bolt Pattern (Metric): 6x135/6x139.7
  • Bolt Pattern (Standard): 6x135/5.5
  • Offset: 2
  • Backspacing: 5.08
  • Center Bore: 106.1
Edited by Russ757
Not running a 78mm hub centric bore is likely to cause a vibration.  Then you'll have a problem pinpointing the vibration not knowing if it's a balancing, wheel or tire issue.  They make hub centric rings but not sure how effective that is. I'd prefer a hub centric wheel. Just saying.
3 hours ago, CamGTP said:
Hub centric rings work just fine if the bore isn't the same size.
I just hate the cheap look of the plastic hub cover.
I've seen plastic hub rings. I think there's aluminum though which would seem better but I'd rather a hub centric wheel.  I'm not a fan of hub rings and spacers.
Edited by mafd2
I've run hub centric rings that match the hub and wheel bore on many trucks I've had.
Edited by jaxcam02
5 hours ago, Russ757 said:
I'm gonna call fuel tomorrow and verify. I can piece together the first set for 1k but the one recommended will be 1.5k and the only difference is 1mm offset from what I can find
So one is 106 and one hub centric bore?
