2018 No start, install new battery still no start
My 2018 Silverado has sat in the barn for several days and I went out to start it and all I get is one click. Turn ignition off and try again, one click.
Took battery to NAPA and they tested the battery, and tester said replace battery.
New battery installed and same thing, one click when I turn the key... not sure where to look next.
Don't think I need to reset anything... so ideas please.
New battery was on charger all night, it did start today but it randomly will just click once with the turn of the key. Looks like my issue may not be solved yet.
Any grounding issues I should consider looking at before I spend money on a starter?
11 minutes ago, newdude said:
Bad battery cables are common, as are starters on 14-18 trucks.  Typically high resistance in the cables.
When you post "Bad battery cables" do you refer to both or just one of them?
Most of the time its the positive, and that short one that's on the battery block but we've had some that get both.
Thank you for that info. I will see what happens as only time will tell if I still have an issue.
if it gets in a "Click" situation, try tapping the starter with something heavy and metal, maybe even while the key is in the crank position, if it starts, you know the starter has an issue, it's common for bad spot on the armature.
This is certainly not what we like to hear, No Tyme.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2018 Chevrolet Silverado. To do so, please send an email to [email protected] with ATTN: No Tyme/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • 1 month later...
I traced the ground cable from the battery down to the frame, which is just behind the passengers right front wheel. I cleaned that contact and haven't had an issue since.
I have read there are issues with both positive and negative cables but for now just cleaning that contact has worked for me.
