Footwell lights 2022 refresh Silverado
I have not even attempted to delve further into it. Figured I would just get a truck that either already has em, or has easily installed upfitter switches. Was actually trying to trade up today to an HD AT4 today, dealer wanted me to take a $20,000 bath on the 1500 with 6,000 miles on it. Ridiculous. I have worked at 7 different car dealers myself, and that’s a big lowball.
  • 5 weeks later...
I want to put some rock lights on my truck that only illuminate when the dome lights are on. Using the door sill instructions to trigger a relay, with power filter to cancel out the PWM, to power the lights might be the ticket.
Just keep in mind the door sill pin will be at a different location for your 2020. The 2022 refresh and up are on the Global B architect.
Correct. Looks like I need to update my bio information!!
  • 3 months later...
I have 2023 gmc sierra elevation and I added footwell leds. You take the last black connector of the BCM towards firewall and slot 1 which is empty I put a paper clip in it and added a but connector to the end of the paper clip connected the wire and grounded the other wire, now my LED’s turn on and fade out with the dome lights and turn on when any door opens. I hope this helps anyone of you trying to put footwell lights on these expensive trucks that should come standard
I will have to give Cluemasters approach a try later. I too have a ton of different molex pins and connectors. If it works for a 2023, it SHOULD be the same on a refresh 2022. I’ll post my findings once I have something to report.
Ok, I went out and tested on my 2022 refresh Sierra Elevation in response to Cluemaster and Low Ufo's post from 2/15 that BCM (K9) connector X1 (black) pin 1 is not occupied, and is indeed where you want to wire into for footwell lighting. As Cluemaster noted, it will turn on and off with the interior lighting (including from the all on/off switch in the overhead lighting module). I tested it with just a small wire jammed in there for the time being and grounded it out to the nuts on the door jamb. Per the GM upfitters manual, the wiring to properly install this permanently would be GM part number 19370262. This is a 5 pack of pinned wires that will plug right in and be locked in place. Find a decent ground and you should be in business. I have only tested 2 of my four LED strips in it so far, as most of the parts from what I thought was a dead upgrade have been buried somewhere in parts bins, so I guess I will be finding all of those this weekend. Also, should be noted that the best pricing I could find on these wires (as of today 10/17/2023) was from eBay from Everett Chevy Buick GMC.
This is great news. Thanks for updating.  Now the trick is to find a small strip of LED lights that match the slightly blue tint and intensity of the stock OH LEDs.  Hopefully you find a good match with the sets you have stored.
I bought a Diode Dynamics footwell lighting kit specifically for this application. Unfortunately, the LED strips supplied are 4000K which is good, but not exactly matching to what I believe is more of a 6000K hue to the rest of the interior lighting. I’m going to stick with it for the time being, if it bugs me I’ll wire in new whiter/bluer weatherproof LED strips. I’m not sure how much that one little pin from the BCM can handle as far as output. While LEDs are low consumption, it’s quite a few LED’s to power 4 separate floor spots. Also worth noting is the wire leads I ordered from Everett Chevy Buick GMC they were selling as just single wires. While technically that is all I needed, I would rather have a couple back ups, so that order has been cancelled and am still on the hunt for the wiring.
I bought a set of 12v leds in Walmart, I cut off the 12v cigarette plug stripped the wires and it all came out great. The led comes with a remote multi colors and I can add any lighting effects to when I open or unlock my doors. Walmart price $9 name is MONSTER LED
Minmax I’m glad I was able to help and 100% confirm that in the black BCM plug in empty spot slot 1 is where you get the job done 👍🏽
Thanks for your contribution Clue.  Those Wmart LEDs are certainly an option, but I really don't want to deal with that coiled cable and control box, as I would never need infinite adjustability.  Ideally, I'd like to find a smaller say 4 to 6 LED strip that's 6000K and fairly dim to match to OEM. I'm waiting to see what Minmax reports back before pulling the trigger on a few options from Amazon to test.  Thx!
The strips I have are VERY nice (from diode dynamics), albeit, incorrect K value, so I am sticking with those for now. This item on Amazon would likely work well, although not as “weatherproof” as the ones I have, if water ever gets that high up in the vehicle, your footwell lighting will be the least of your worries. You can likely leave the potentiometer installed and make little strips for each footwell, all spliced off of a four way splitter to make each strip controlled by the potentiometer. Or snip after the potentiometer and let the truck give it full voltage. They big part is the four way pluggable splitter that came with the Diode Dynamics footwell kit I got.
Lepro LED Strip Light White, 16.4ft Dimmable Vanity Lights, 6000K Super Bright LED Tape Lights, 300 LEDs 2835, Strong 3M Adhesive, Suitable for Home, Kitchen, Under Cabinet, Bedroom, Daylight White
