Windshield Trim: What is this part called?
I have 2014 Sierra. At the bottom of the windshield there is a trim piece / moulding that meets the windshield glass. It is not seated properly and sealed and kind of wavy. I guess it's intended to seal to some degree and let water roll over. Is this cosmetic or is there an easy fix? Pic attached. I've tried to press it down but not much luck. Im hoping not to have to replace the whole piece which looks like it'd be quite involved and taking off wipers. 480FA999-.jpg.5f5b5f9f97e771ef46298725944f0e4a.jpg Thanks
  • 1 year later...
  • 8 months later...
Old post, I know. Was hoping you got the answer. That black rubber trim, right? My 2015 Sierra AND mu 2015 Yukon both have the same issue. We're you able to order it?
The rubber trim is part of that large plastic cowl piece (air inlet grill)  I don't believe it can be purchased separately.  I replaced my inlet cowl for the same problem.  Usually the two end parts (on the corners) of the cowl will need replacing too.
@Texasdeere Thanks. I think I'm gonna try a windshield replacement joint and see what they have. The 'cowl' part is still in good condition. The rubber strip is all that has weathered out. I will update when I find out. 😀
How about trying a heat gun to smooth out the waves?
Hello, I was the original poster and forgot about this thread. I never did anything about it. That piece is still wavy. It doesn't bother me that much, I was mainly concerned if it was causing a leak anywhere, to which I don't think it is. If you figure anything out, please let us know. thanks
