Are you still using premium gas?
There have been threads on here before regarding the use of regular vs premium gas in the 6.2L.  I used to always use premium in my 2020 Denali.  Recently the spread between them has reached $0.80 in my area so it isn't just a couple dollars more on a fill up now.
I started using regular and really don't notice a big difference in performance.  I haven't tried to figure out the difference in mileage yet.  Has anyone done that?
I have never put anything other than L87 in my tank and have never had any pinging. My mileage seems to be on par, too. I get about 19 on the freeway. Chevy recommends that I use premium, but I recommend that I don't.
Edited by reeseb
  • Haha 3
I have never used anything but 87 octane in my 2020 High Country HD with the 6.6L and my new 2022 Denali with the 6.2L.Never had a single issue and I dont expect any.
The reason is performance. The PCM is programmed with Low octane tables and high octane tables both. It will move to the low octane tables based on the ping ( KR ). The Low Tables are designed for 87. Yes, you will  have a slight performance lost, but unless you are heavy towing or drag racing it, then the Low Octane tables will handle your drive with no issues.
You knuckleheads running 87 in your 6.2s let us know when you sell your truck so we can avoid it.  Broken rings and pistons are in the motor's future.
Y'all ought to get the motor you can afford.  As for me and my house, we will always burn E85 or 93 in our FlexFuel vehicles regardless of price.  God provides for our needs.
  • Like 5
They will not. Ever heard of knock sensor? Are you WOT at every chance? Towing? If not, then nothing will happen. Also, I assure I can afford 20 dollar a gallon gas if I wanted. That doesn't mean I will blatantly piss away 10 bucks a fill up if I'm not towing or drag racing my truck. But please, tell us all how you know more than everyone else.
Edited by 1454
  • Sad 2
I put 20k on my truck driving back and forth to Jersey from NC last year and saw between 20.5 and 21.5 regardless of 87 or 93. The only thing that gave me actual more mileage was using non ethanol fuel. Which inherently makes sense because ethanol is less energy dense.  88 gave a solid 22 mpg every trip.
  • Sad 1
They do, it is not speculation, those of us who pay attention have witnessed it.
Your high compression engines knock/ping while driving around town on that 87 swill.  You cannot hear it.  You take off from a light, the motor knocks and the computer pulls timing.  You go to pass a guy, even without downshifting, the motor knocks and the computer pulls timing.  1000 more times on your trip to the mall and back.  You don't think that will take toll day after day, month after month, year after year?
I don't know more than everyone else, I paid attention and learned it here.  You can too if you do your research.
Last time at the drags I took a video from inside the cab, from the stands and took a Snapshot with my Tech-2 to show you guys that the motors do knock and you cannot always hear it.  I am not tech savvy enough put three videos into one but someday my kids might slow down and help me post it for y'all.
Myself and others have posted videos from youtube of 6.2s that came apart because of prolonged use of low octane gasoline.
  • Like 7
I went to tech school first for automotive technology, and then for a BSME. I didn't learn what I did from a message board. If you aren't under heavy load, cylinder pressures aren't enough to cause detonation. No manufacturer is going to sell a engine today that a slightly lower octane will cause them warranty work. But yes, you know more than everyone who has shown this isn't the case because someone posted a forum topic on "muh 87 causing detonation, omg."
  • Thanks 2
  • Haha 2
Well, you know so much that isn't so.
Make sure you let us know when you sell your car so we can all avoid it.
https://pickuptrucktalk.com/2020/10/misleading-these-trucks-recommend-or-require-premium-fuel/#:~:text=GM recommends using 93 octane,economy you must use 93.
Recommends and Requires do not have the same meaning.
Question! As GM's RECOMENDED 93 is not available everywhere in the USA does that mean those who live in areas without 93 can 't own a 6.2? :dunno:
Kiddo's my little much hatted by most 4.3 RECOMMENDS 87 octane and pulls up to 10 degrees KIR on every hill or major headwind. It's also a Flex Fuel vehicle and pulls zero KIR when using something over 40% ethanol and more interestingly does about 3% better that the carbon balance would indicate which speaks to GM's claims the RECOMMENDED USE of higher octane fuel will ENHANCE PERFORMANCE AND MILEAGE.
IF KIR knocked rings out of motors there would be heaps of dead 4.3's littering the highways.
Does that mean others observations of damage are in error? 🤔 Absolutely not. Some knuckle heads think towing heavy on 87 is a good idea and they will suffer for that mistake. KIR will not pull an infinite amount of timing.
  • Like 4
  • Thanks 1
