Help with MPFI 1993 K1500
I have switched from TBI to EdelBrock MPFI the injectors it originally came with was 19lb PICO injector https://www.edelbrock.com/19-lb-hr-pico-fuel-injector-qty-1-3574.html
The issue is that they’ve gone bad and they’re expensive and backordered several months out.
could I replace the current injectors with 35lb PICO injectors and tune them at a shop and be ok?
https://www.edelbrock.com/35-lb-hr-pico-fuel-injector-qty-8-3636.html
If the Edelbrock kit you have allows you to tune that device for a larger injector, then yeah you could do that.
I would assume it allows you to change the injector size and data for it. I'm not familiar with it but does it have a computer with wideband sensor that does auto tuning?
