Accessory Wiring
The 12v outlet on the dash is energized all the time. I would like it to deenergize when I turn off the engine. I have considered adding an additional 12v outlet and wiring it to the accessory side of a fuse panel. How do I accomplish either of these scenarios?
In the Instrument Panel Fuse Block Right (passenger side), move fuse F28 to F27 (note: center connector is common for both positions F27/F28.) F27 is Accessory power outlet/retained accessory power (RAP). All dash USB ports and 12v outlet will turn off when truck is shut off and driver's door is opened (or about 10 mins after truck is shut off if driver's door is not opened.)
  • Thanks 1
