Similar Content
- 2 replies
- 8,069 views
- 21 answers
- 29,347 views
Recently Browsing 0 members
247.8k
Total Topics2.6m
Who's Online 5 Members, 0 Anonymous, 802 Guests (See full list)
Question
Robert Mitchell
Hello. I have a 1989 Suburban. 5.7 2WD. Automatic transmission with OD 784K miles.
Edited by Robert MitchellStarted out with throwing an intermittent code 32: EGR MAP fault. Changed all the related accessories. (EGR valve and solenoid. Map sensor, Water temp sensor, throttle position sensor) This did not fix the problem.
As time passed. Check engine light / Code 32 would intermittently show up after engine was fully warmed up. It will usually, but not always appears at idle and vanishes when RPM is increased.
Recently. Check engine light would intermittently turn on when you activate the brake petal switch. Or, light would intermittently flash when you manually shifted from drive to OD and back.
After troubleshooting with a IR camera, I discovered that the ECM-B fuse runs very hot while engine is running. Nothing else accessible appears to be unusually warm with the accessible areas of the wiring harnesses. Not sure what the ECM-B would have to do with it but.........
Any good ideas would be appreciated. Thank you.
0 answers to this question
