Align after mild leveling kit?
OK, I tried searching around, but got limited results.  However from those results, I'm getting the idea that you guys all recommend a new alignment after a leveling kit?  Even a mild kit like 1" on the front?
Edited by belchfire
  • belchfire changed the title to Align after mild leveling kit?
Always.  Even with a small one 1 inch, it will throw the toe off at a minimum.  Caster/camber on such a mild raise probably won't need to be touched, if anything it would correct it a bit back to stock spec range.  But your toe will go out.
Edited by newdude
  • Thanks 1
