I'm stuck in 4hi...Help!
I recently purchased a 2014 Silverado 1500 LT 4wd with 113000 miles. The 4wd service light is on and I have tried pulling the #6 fuse and putting the selector into different positions then reinstalling the fuse with the key turned on as I read on another post that this worked for someone else. I was able to get it to work for a day then it went back to the 4wd service light. I have a new shift motor that I want to put in but it seems like the old one is under some rotational tension while in the transfer case. Does anyone know if I can remove this motor while it has tension on it...
Welcome to the site.
14 and 15's had a problem with the transfer case sticking in the cold weather. There was a reflash (TSB) done and it cured the problem. Maybe have a dealer run your VIN to see if it was ever done to the truck.
