Brake problems
My 2018 GMC Sierra doesn’t stop as good I think it should. My 15 Silverado stoped better.  I’ve tried better pads didn’t help. I installed power stop kit on all 4 corners and no improvement. I had it to the dealership they just blew me off. I’ve checked the vacuum pump output lowest it falls in 9 inches of vacuum. My next thing is do any of the techs on here know what the brake psi output is supposed to be.
I'm sure you could test all this and be pretty accurate.
I did a little looking and found somewhere that said the stopping distance at around 60mph was in the low 130's for feet distance. You could find a rural area or dead end road to do this on. Mark the ground where you start to brake with a cone or something and measure out to 120, 130 and 140 feet, slam on the brakes and see where you land. If you are within the 120-130ish foot range, it's stopping as it should.
Maybe double check those numbers with Motortrend, Edmunds etc etc to see what they tested at.
