Any lifter failures in 5.3 without DFM
As stated though, all the internals for DFM are still present. It is only missing the computer hardware/software side that would allow it to function. Non-DFM engines are still seeing failures.
On 1/7/2022 at 7:43 AM, Stifler said:
OK I will be the dummy... there are 21s with no DFM? or are you talking disabled with a tuner? How do you know if you have or dont have DFM?
GM built some 21's without DFM (turned on), it was reportedly due to the chip shortage.  Your Monroney window sticker calls it out.
Got a link to such a report?  I have not seen any.
On 1/10/2022 at 4:43 PM, Byrds8 said:
No, someone else in the forum told me the same thing. But I do understand why. They arent going to rebuild the entire engine and have different ones because of the chip shortage.
I was referring to a link of a report of DFM lifter failures on the "non-DFM" engines.
Again, no someone else mentioned they were in the forums. I was just restating as said in my original mention of it. I cannot verify one way or the other. From a personal standpoint, mine has just under 2600 miles and I have had no issues with the engine at this time. Well, other than the cold start noise that goes away after 20-30 secs.
I know this is outside this threads range. Here it goes. In my almost 50 years of driving I’ve never had a lifter failure. Iv only had one engine go bad. I’ve had warning of engines getting worn out by getting noisy or using oil. Never suddenly just failing. Transmission either. There’s no warning anymore, boom done. Progress.
Edited by KARNUT
We've sold a bunch, zero in the field factory DFM disabled failures that I can report.  SupremePizza said "yes" on the first page, I replied to him to give any recent examples, never responded.
So as I see it, until there's one witnessed at a dealer from a tech and they posted somewhere online about it, or an owner reports it in the field, its zero on here so far.
Lifter isn't deactivating so odds of failure go to near zero.  Is it possible still for one to fail without actuation?  Yes.  But again, super low odds.  Saw one in the 14-19 Facebook group who had a Range or was tuned out and had a lifter still go.
Edited by newdude
@newdude. So are you stating that it’s more of a DFM issue, bad lifter issue, both? Looks like you are a mechanics and my father has recently retired so no more free work shop space!!  😂🤷🏼🤦‍♂️
Im just asking because my stepdad bought his 2020 Sierra SLT, loves it but has put 40k miles on it in little over a year and he is thinking of trading it in. I converted him over to GM after Ford for years. I don’t want him to trade and then have to worry about lifter failure. He can get excellent money on his trade in now and upgrade to a Denali instead of a SLT for the money.
I’ve  told him to wait another year and get the new refresh but who knows when will that appear on lots and will they still have issues.
my 2019 and his 2020 have been flawless. Neighbor has 2020 LT and his has been great as well. My boss has 2020 LT no issues with his either or 8 speed tranny.
thanks for any info.
DFM is just the name of the newest cylinder deactivation.  DFM and AFM are in the basics the same thing, difference is DFM has all 8 cylinders equipped with active lifters, AFM its only 4 cylinders.  DFM can also alter the number of cylinders in operation from all 8 to as little as 2, where AFM is the same 4 cylinders can deactivate, V8 or V4 mode.  Both systems use the same exact lifters.
The issue with both systems is the possibility of active lifter failure.  The internal spring and locking pin mechanism is the most common culprit.  Control solenoid failure is a possibility as well but not as common.  Oil aeration, a miss timing of the solenoid sending oil to collapse the locking pin, a miss timing  of the solenoid closing and taking oil away causing the lifter to lock back in prematurely, lifter sticking in the bore.
Like all other oil operated systems in modern engines, clean oil and good oil pressure are a MUST in their operation.  I'd say a majority of the ones we've done all were on high oil drain interval vehicles, so over 6,000mi between oil changes, but I can't say that 100% a shorter drain interval would stop lifter failure.  I have no further data to support that.
The most recent rash of lifter issues was a production issue.  GM had a known batch of bad lifters made from September 2020 to March 2021.  This is the reason for the latest bulletin on the 2020-2021 trucks.
Edited by newdude
  • Thanks 1
So, give me some clarification here if you don’t mind. What I’ve read is that the problem has predominantly been with DFM engines, but you’re saying that they’re identical lifters on both engines.
So, on my 2019 Silverado Custom L82 5.3 AFM engine, manufactured in December 2019, that I may very well have a problem eventually as well?
I’ve got just over 18,000 miles on it so far with no issues at all, the truck has been great and runs great - so far!
Thanks in advance!
Works for me then. I thought about trading in mine just to get a black 2022 one but after I saw they all had DFM on It was a hard pass. Glad mine doesnt.
Since I have a factory disabled 5.3 that makes me feel better. Previous was a 08 5.3 AFM that I traded at 100k that never had an issue.
Question on the bad batch of lifters. Are the Sept 2020 to March 2021 engine dates or vehicle completion dates?
I have also been curious about those dates being engine build dates vs truck build dates. I have a DFM factory disabled Sierra with a September 2021 build date.
    247.7k
    2.6m
    Brent Wylie
    Brent Wylie
  • Who's Online   1 Member, 0 Anonymous, 830 Guests (See full list)
