Leaking valve cover gasket?
2017 5.3 106,000 mi. Is it a normal thing for the valve cover gasket to suddenly start leaking? I started it up and drove about 30 minutes to work and when I parked I smelt burning oil. I checked under the truck and didnt see any oil leakage anywhere so I am figuring it is leaking from the valve cover onto the exhaust manifold and burning. I havent taken the "shielding" off over the top of the valve covers to look and I will have to wait until it warms up and the 16" of snow to melt, maybe come March. Any-who, how hard will it be to change it out? Anything special I would have to do, or is it just as easy as my 90's model pick-up? Thanks in advance for any info you may have.
Gary
Gary
   Diagnosing the problem is 99% of the issue.
 Guessing is the same as gambling.
So... You a ... gamble'n man?
It's not the valve cover gaskets, its the rear main.
Pull the transmission out and replace the rear main.
 Not trying to be a douche, I'm just saying that you must find the problem before you can fix it.
True! Like I said in my post, I will do that when the weather and ground conditions allow it.
 I Do live in Nevada where gambling is legal!
And you know this for fact? Did you come over last night during the snow storm and crawl around to confirm this, because I haven't seen any tracks in the snow! Plus there isnt ANY trace of an oil leak either on the ground, bell housing, or on the exhaust down pipe back.
I guess you are a "gambling man" unfortunately with your statements above, it sounds like you want to "gamble" with my money!
Sorry to say but you did come off sounding like a douche, and like I said, I will seek out the problem when weather and conditions permit.
Edited by Gary Shull
Added more info.
