Temp question
Hopefully some can help me. I have a 2015 gmc sierra 1500 5.3. The last few days I have noticed that the temp gage go's up to 210 then starts to fall a little. It has always ran dead on 210. It drops 1 or 2 marks then goes back up to 210. I assume this is the thermostat going bad? Just looking for some advice before I change it and hope that's it. Thanks.
Could be sticking open a tad but what you see isn't a huge problem. If you watched the temps with a scan tool or OBD2 code reader with live data it probably still shows 200-215 degrees like most do.
If it's running down at 180-190 all the time then I'd change it out because it's for sure sticking open then.
No, that little change in running temp wouldn't cause a drop of fuel mileage like that.
Colder weather, driving style, remote starts and extended idle time for sure would though. My fuel mileage always drops in the winter months because I only drive city speeds.
Do a search for cycling thermostat Bad news is it can cause your radiator to crack and leak good news is you noticed it and can replace it. GM has a new updated part be sure you get the right part.
Yotaman
Edited by Yotaman
Yotaman
I had the radiator and thermostat replaced about 5 years ago because it cracked and had wrong thermostat in it. I assume it has the updated one now?
I think this would depend on who did the work. If it was a GM dealership, you will most likely have the proper thermostat as GM usually frowns on dealerships installing modified parts.
Yep it was the GMC dealer I bought it from. The one that came in it from the factory only made it about a year then cracked the radiator.
