seat movement 2016 Silverado
There is a service bulletin that addresses this. There is a kit to eliminate this and it's mentioned in the service bulletin. I will try to find it and post it.  I don't recall the specifics but I know on mine, when I go around corners  I can feel a very slight thunk sometimes. It's a bit aggravating but not quite bad enough where I felt it needed to be done, for now...
Ok, take a look at this thread. The link I posted is towards the end but you can bounce around for several diy fixes. They range from zip ties to washers on a torx bolt to rubber washers and hose clamps. Each one has had its successes and seem simple enough to do.
And I found the service bulletin that has the parts list if you feel like doing that method.
MC-10135401-9999.pdf
Edited by mikeyk101
