2014 GMC |Sierra - No rear left/Right turn signal, no driver side brake or running light
i currently have a rear left and right turn signal failure and no running light and brake light driver side. it all started after i washed under  my truck. i have check the fuses and they are all good. put in new bulbs and still same issue. also have disconnected the battery for over a half hour and still same issue. ive tried to clean all the contacts with cleaner and still same issue
help please
21 hours ago, K Palmer said:
I did use a pressure washer. I’ve checked all the fuses and they are good however maybe I’ll change them anyway
I always use a pressure washer clean the underside of my truck and never had an issue.
Still, as @CrawlSlow mentioned, it's worth checking out.
