LT Trail Boss Grill "Bar" Replacement
I looked into this because I’d like to do the same. I don’t believe it comes on its own, at least not from GM. There is no part number for just the “bar”. Though it is separable, it’s wrapped into the whole grill.
There are some on eBay for around $350-$400 but they are not cosmetically perfect. You could watch eBay like a hawk for a while and probably get lucky.
Also consider having it vinyl wrapped, I got a quote for this locally for $250.
Even plasti-dip it, that would cost you near nothing and you’d have the same look.
On 9/18/2021 at 3:43 PM, GarandPappy said:
Does anyone have the GM Part Number for the LT Trail Boss Grill "Bar"?  I don't need the entire grill.  I just need the "bar".  I have a white RST, and I would just like the grill bar in black instead of white.
THANKS!
It's a bit confusing. GM has 2 part numbers for the front grille. The first is the "part" from the Trailboss (84493318), but there is also an official GM Accessory for a Black Grille (84320548) which is considerably cheaper and appears to be the full grille as well (https://bit.ly/3EGbcuj). Not sure what the difference is.
I'd call your local Caliber Collision or something. I just got rear ended and found out that they have access to more parts than we do as consumers and can get components to things that are shown as full assemblies on the parts websites. You may be able to get a part number out of them and get it ordered that way.
Edited by shanemoon
