DANGER/Adaptive Cruise Control Malfunction
Had my cruise set on 75 going down the highway and came upon a Semi truck, the adaptive cruise didn’t slow me down like it normally does. All of a sudden my seat vibrated , a bell went off, and a message came across the screen saying that the adaptive cruise temporarily unavailable. Immediately , put the foot on the brake and missed ramming into the back of the Semi. Not fun! Turned off the cruise then back on again , 10 minutes later another malfunction with no cars in front of me. Called the dealership to see if there was a recall or TSB, they were unaware of one. My truck is 2 months old with 2600 miles. This is a serious issue , came close to getting into a very serious accident. Taking the truck in on Monday , which is the first appointment I could get after calling several dealerships. I do a lot of highway driving and I need to be able to rely on my vehicle, this is not a good situation . GM if you read this please respond and let me know how I can get in touch with someone regarding this.
Just because you have adaptive cruise doesn't mean you don't have to pay attention to your surroundings and safely operate your vehicle.
  • Like 6
  • Thanks 1
5 minutes ago, shakenfake said:
Obviously he was paying attention to his surroundings, he didn't hit the semi truck.
Comments like these don't help the man. If what he says is true then this is something that needs to be addressed by GM.
"All of a sudden my seat vibrated , a bell went off, and a message came across the screen saying that the adaptive cruise temporarily unavailable. Immediately , put the foot on the brake and missed ramming into the back of the Semi. "
That's not what it sounds like to me.  Sounds like panic braking.
  • Like 7
I don’t use it on freeways only two lane roads. I find myself while paying attention like usual going slower behind slower vehicles. The slow down is so seamless. Where as regular cruise you know when Your approaching a vehicle. I lose my flow. Two lanes  it’s more relaxing.
I agree 100% so I guess if he hit the truck it would have been GMs fault. People think with all these features they can just sit back and read a book while driving down the road.
  • Like 4
Did he hit the semi? He felt the vibration and the bell went off and to top it all off he read the screen. I think he must have been paying some attention 😉
Edit: I'm willing to bet "Barely missed the semi", is he is a couple car lengths away and is exaggerating.
Edited by shakenfake
Are you guys nuts. I was able to avoid the truck because I was paying attention. It wasn’t a panic situation , but it was a close call. The adaptive cruise is supposed to be a safety feature . Right now mine is not . They have all these technology features so as to make the vehicle safer to drive. I wanted to alert others of a potential serious issue with regard to this matter, and see if anyone else has had any problems. Try to avoid speculating as to what I did or didn’t do because you weren’t in the truck with me when this happened and more then likely your getting it wrong .
  • Like 3
  • Thanks 1
https://www.caranddriver.com/research/a32813983/adaptive-cruise-control/
What Is Adaptive Cruise Control?
"These sensory technologies allow the car to detect and warn the driver about potential forward collisions. When this happens, red lights begin to flash, and the phrase 'brake now!' appears on the dashboard to help the driver slow down. There might also be an audible warning."
Thankfully you did not wreck your truck.  I have had very similar experiences with the adaptive cruise control.
Most commonly it is when the sun is very low on the horizon and blinding the camera sensor.  Other times it is in high fog conditions or other conditions of extremely reduced visibility.  Any kind of ice buildup directly in front of the camera will also disable your adaptive cruise.
It may not actually be a system malfunction it may actually be a limitation of the camera based system I think there's a warning about this in the owner's manual too I'll have to look it up later.
One thing I didn't think of is closure rate...with good visibility and moderate closure rates on the highway it really does work well.  High closure rates...it does freak out.
Good luck
Edited by calgator73
Good luck
Using any type of cruise control while driving in fog or on ice is probably the cause of 100+ vehicle pile-ups that always end up on the news.
I never once had a problem with the radar adaptive cruise control in my car.  Although it rarely gets used, the two camera Subaru Eyesight system in my wife's Outback has always worked flawlessly.  I always thought it was a bad idea to have an ACC system based on one camera.  GM dropped the ball on this.
