Driver side brake light.
All my lights work by my driver side brake light do not. They work perfectly at night but will not work when turn signal is on and when brake pedal is pressed. I have checked the fuses under the hood and even put in new bulbs. I put a voltmeter and it seems like the black wire does not get any power when brake is pressed. On the passenger side harness the black wire gets 14 volts when brake pedal is pressed and 0 when not. Could it be tail light junction box?
