2013 gmc sierra 2500 hd
That's not how things work. Different injectors don't increase horsepower.
The 6.0 injectors on your truck are already large enough to make more power than the stock 6.0 can make. It would even handle mods like a camshaft and headers.
If you want more power, you need to add more air. So think camshaft swap or headers to increase the horsepower.
If your 6.0L is Flex-Fuel, the stock injectors are high flow.  The Flex Fuel injectors are 50 lb/hr Delphi's, and they are what a lot of people upgrade to.  Check to see if you have these injectors:
 https://www.lsxceleration.com/delphi-gm-50lb-hr-ls-truck-flex-fuel-injector-12613412/?utm_source=google&utm_medium=cpc&adpos=&scid=scplp7612&sc_intid=7612&gclid=Cj0KCQjwm9yJBhDTARIsABKIcGYYLD5sUYNpQ-IJ7Tmv-4LV6FyucxCU4MEXVrzEDmdaLP0nCAGCeVIaAivwEALw_wcB
13 hours ago, CamGTP said:
Injectors don't increase horsepower. I replied in the other thread he made.
True, injectors by themselves will not do anything.  If he has the Flex Fuel injectors they should be more than enough for whatever other reasonable mods he does.  Non-Flex injectors are still probably good enough.
Edited by C/K Man
  • Confused 1
  • 1 month later...
whats the flow rate vs LT1 or LT4 injectors?
