Service Trailer Brakes
On 9/7/2021 at 10:25 PM, NWI Denali said:
So I finally pulled the code. Looks like a pretty generic code, loss of signal. U0137. Could this be a bad ground? Any insights? Anyone ever have this code?
Check ground G400.  On the frame at the rear most crossmember.  Find the junction panel where the tail lights are, then look to the right.  You will see a single wire coming off the main bundle to a ground location.  Check that one and clean if necessary.
PIT5562: (Inspect Ground Bolts) Multiple Electrical Issues Including Stall / Crank No Start / Lighting Issues / Memory And Power Seats / Power Windows Inoperative / Heated Cooled Seats / Trailering / ABS MIL / Stability Message - (Apr 17, 2017)
  • G400
Service Trailer Brake Message
Trailer lighting inoperative
Trailer brakes inoperative
Left Rear Turn signal failure message
No communication with the Aux Chassis Control Module
Left turn signal fast flashing
License Plate lights inoperative
Reverse lights on dim
When in Reverse, left reverse light is inoperative
Cargo lights inoperative
Aux Chassis Control Module:- P0562, C1113, C111B
EBCM: U0137
BCM: B3883
Edited by newdude
You are the man, newdude. I know this thread is pretty old now, thank you so much for following up. I ironically have an appt next Wednesday at the dealer, so I will clean that ground this weekend and report back.
Are you a gm tech? You seem extremely knowledgeable. Thanks again.
  • G400
EBCM: U0137
BCM: B3883
Well, I finally have a resolution. Had my dealer diagnose it and they actually found the harness rubbed through on the frame near the rear wheel well. Looks like there's a mounting bracket for the brake lines is what did it. They repaired the harness and all good to go now. Thanks to all for the help troubleshooting.
  • Like 3
  • 5 months later...
I have not seen where exactly they repaired the harness, just going off of their word. They said where it runs along the frame rail near the driver rear wheel well.
Are you getting the service trailer brakes message? Have you replaced the other 3 parts like I did as well?
  • 1 year later...
If you don't mind, how much did they charge you for that fix?
  • 3 weeks later...
    247.8k
    2.6m
    MinnieKing
    MinnieKing
  • Who's Online   4 Members, 1 Anonymous, 936 Guests (See full list)
