04 Bose w/ no a-pillar speaker?
Recently bought an 04 Silverado 3500 LT with the 6.0 gas.  I know there are several different bose setups but haven't found a straight answer.  I've got the Bose RPO code and the door speaker grills say Bose but I don't have the "tweeters" in the a-pillars and no sub in the counsel.  I pulled the A-pillars off to see if there was a plug behind them in case they were swapped out at some point but didn't see one unless it was tucked down behind the dash.  So was this an optional bose setup?
No Bose in AA pillars or Console, only 6 speakers and that's 2 in the front doors and one each in back doors.
 The Sub is NOT available with a regular cab , OR a split front bench seat.
 So , if ordered, its priced according to your seating.
 I believe  you could order the bose, even with front buckets, and NOT check the "Sub" box,
and get what you have, which is very common by the way.
