2021 Silverado No cabin lighting at entry. What is fuse nomenclature or location?
I'm not sure there is a fuse for the cabin lights, I've added underglow to that circuit off of the BCM and accidentally drew too much power and the BCM just tripped and reset 3 times trying to turn on the load until it gave up until I turned the light off then on again.
Also it is a PWM dimming circuit coming out of the BCM
BCM (Body Control Module)
PWM (Pulse Width Modulation)
9 hours ago, Fran said:
What is the nomenclature or abbreviation GM uses for cabin light fuse(s)? That operate on door opening?
I have to ask...did you check to see if the button is on, on the upper center console?
