Looking to wire light bar to rear cab light swich
I added two light pods to help when reversing at night but didn’t want them to come on each time I put the truck in reverse so I tapped into the cargo light fuse.  the cargo fuse is located in the dash on the passenger sode.
I installed the lights with the relay mounted under the hood. For the switch connection off the relay I ran the wire through a rubber grommet on the passenger side door.  Then tapped into the cargo light fuse.
Here are a couple of pictures that may help. Good luck!
