GMC Sierra 2004 Alternator upgrade
Dear All,
I've changed the original belt driven radiator cooling fan in my GMC Sierra 2004 to an electrical driven type and want to know what is the best alternator to install to overcome the amp loss without adding/modifying alt. bracket/holder or wiring connections please?
53B60867-70B9-4B6D-9E12-BA39694B21C4.thumb.jpg.77f76f5bde879ce87a331c645f736262.jpgF16BE918-50CF-4780-A810-CF6BCF2C255F.thumb.jpg.f1b05b54c4aecb3339103fc1b7879584.jpgDAD12319-74F2-4B39-A7CC-C30CDDF91EB6.thumb.jpg.e4bcabe3c3b4edd7990af5babdd14d32.jpg
Regards,
On 6/7/2021 at 2:43 PM, Sharpz said:
I think a 145 will replace the 105 amp, same bolt pattern pully etc.
Hi Sharpz,
I've changed the alternator as informed and worked fine. thank you
I also added 2 nos. of temp controller connected to each fans relays to adjust the required on-off rating for fans and going fine with me now.
On 6/14/2021 at 2:39 PM, Abdulla Muhsen said:
Hi Sharpz,
Hi All,
I have connected the 42 pin which is for low speed fan, where is the connection for the fat speed fan? some of wiring diagram shows pin 33, but it is not the one in 2004 GMC. Do I need to connect the fast speed fan relay wire to AC clutch wire?
Regards,
On 6/18/2021 at 2:35 PM, Sharpz said:
This is a question you should ask the community as a whole, in a new post.  I am all stock and havent did the fan swap.
sorry as im new in the forum i thought its going to all.
Noted
On 6/7/2021 at 8:51 AM, Abdulla Muhsen said:
Dear All,
Regards,
Hi All,
