Rear Seat Reminder
40 minutes ago, NCCaptainMorgan said:
Got my new 2021 AT4 HD and love it.  Every time I turn it off it tells me to check the back seat.  I thought it was only supposed to tell me if I had something heavy enough in the back seat.
I could be wrong but I think it will say it if it sees that you opened the rear door and then resets on the next ignition cycle.
  • Rear Seat Reminder
    • Helps to remind the driver to check the back seat(s) before leaving the vehicle
    • Activates when rear doors are opened and closed up to 10 minutes before or anytime while your vehicle is on
    • Under certain conditions, once the vehicle is switched off, designed to sound 5 audible chimes and display a visual message within the Driver Information Center
    • Activates only once each time the vehicle is turned on and off, and would require re-activation on a second trip
