2015 Sierra 1500 5.3L V8, Qs about differential fluid change
Want to DIY  differential fluid change myself
1. GMC recommends
rear differential fluid 75w 85
front differential fluid 75w 90;
Can I use 75W 85 for the front differential? is it supposed to be better than 75w 90?
And I live in Canada, it can get to -45 celsius in the winter, -10 and below from Nov. to next Apr.
2. How much I need for the front differential fluid change? how much I need for the front?
Thanks guys!
Edited by Zhiyi Clement Fu
I would consider Amsoil with those temperatures.
Amsoil web site good for capacities.
For your truck https://www.amsoil.com/lookup/auto-and-light-truck/2015/gmc-trucks/sierra-1500-pickup/5-3l-8-cyl-engine-code-c-l83-2/?volume=us-volume
I was out yesterday and Taptalk still isn't working.
Yes as stated just use 75w-90.  It will work just fine even with your extreme cold temperatures.
The front differential takes 3 pints and the rear takes 4.2 or 5.1 depending on which diff you have.
Like stated above you can look up what your truck takes here.
1. GMC recommends
Thanks guys!
I just did my front and rear differentials last week.  It took just under 5 quarts between the front and rear diffs.  I used the Amsoil 75w-90 product everyone recommends in this thread.
