4 issues to be resolved
1 hour ago, kylant said:
Well, I finally got my truck back after 66 days at the dealer. Everything seems to be good except they did not replace the front brake pads per the TSB, only the rears. Asked why, said pads are on backorder. I said the parts department told me they are in, they called me. Service guy checked, sure enough, they are in under my name. So truck now has to go back again for the pad replacement. 🤬
Intermediate steering shaft seems much better, time will tell. They indeed installed the new part number shaft. It is clearly labeled.
Rear window seems to be fixed (we had good rain, no leak).
New rear axle housing appears to not be leaking 👍🏻
Man I feel for you. Sure hope this ends your problems and you can move on to using and enjoying your truck.
