Larger Titan Fuel Tank
Looking at getting the larger 60 gallon Titan fuel tank installed on my new Silverado 3500 HD, Titan item# 7010320. Anybody have experience with this tank? Is there any way to reset the DTE calculation in the truck computer for the higher capacity tank. I know this is an option with Fords.
  • 3 weeks later...
Guest Phobby
No, but Titan requires hacking off part of your truck for install. If you have a long bed SB Filters has a 70+ gallon being made for the long bed trucks.
I have the 60 gallon Titan now for a couple of months. Everything seems fine however you have to slow pump the last 10 gallons to get the full 60 gallons in. The fuel gage and the mpg seem to be working fine and I think the miles left in the tank has slowly been recalculating. Every time I fill up it seems to be going higher. I don't feel the need to have anything adjusted. You do have to cut the bracket that holds the fuel filter however nothing would need to be put back if you ever wanted  to re install the old tank. So far completely satisfied.
I'm happy to read that the DTE is slowly adjusting for you.  I just finished installing an S&B 62 gallon tank in my 2021 3500 SRW SB.  So far as I know there is no way to adjust the settings within the truck itself, so hopefully as time goes on my truck will adjust same as you are experiencing.  Gives me some hope!
I just installed the SB Filters 62 gallon tank in my 2020 3500 hd crew cab yesterday. Fairy easy install but i had the truck on a lift. SB states on their website that they currently donot have the software update for DIC but will inform owners when it comes available, they use a third party software for updating it.
