Rear emergency (parking) brake.
So I have been battling my rear brakes on my 2016 2500hd Silverado over the past few days and am at a loss. I have searched high and low on help in regards to why GM, "in their infinite wisdom, " put two return springs on the parking brake shoes, the section that ties into the cable operation part. Then where the adjuster wheel is a much smaller spring. Regardless, I'm trying to replace the hardware on each rear wheel due to frozen caliper slide pins. Oh and finding on of said springs broken in pieces just rattling around inside the inner rotor area. HTF do you get the inside spring out behind the reluctor wheel part of the hub. Mine has the 4 wheel antilock brakes so there is a speed sensor or whatever in there as well. It is so frustrating at this point I might as well just remove the axle a hub assembly. Or is that how it is supposed to be done? Please any insight would be much appreciated. The more detailed the better. Thanks
Mike McClure
Your welcome. If you have never done that before I would recommend bringing it somewhere you trust and have them do it. The hub requires a special socket to remove the nut and then a puller to remove the hub from the axle. The inner seal must be replaced whenever the hub is removed and then the bearing preload has to be correctly adjusted when it goes back together. Also replace the axle flange gasket while you have the axle shaft out.
