Trailer brakes
52 minutes ago, Leopardtech said:
Do you have a factory brake controller?
Yes factory controller with 7&4 pin trailer connections and my trailer has electronic disc brakes with the 7 pin connection
18 minutes ago, AnacortesArmyGuy said:
I assume you mean will the factory brake controller in your truck work with the 5th wheel's electric brakes.  If so, the answer is yes.  That also assumes you have the appropriate 5th wheel connectors on your truck.
7 pin on both trailer and truck
Wait....are you talking about electric over hydraulic disc brakes?  Out of the owners manual:
Only use the ITBC system with electric or electric over hydraulic trailer brake systems.
