Re-Learn TPMS Sensors after tire rotation
Approx 6 months ago I rotated tires and used following procedure to re-teach new position of wheels on 2020 Silverado 3500 HD (SRW).
Today, attempted to do the same and unable to see the tire pressure screen.
A software update was performed 2 weeks ago, curious if something changed or something else wrong.
Any suggestions appreciated.
Manual relearn procedure, Using Uplevel DIC, 2015-2020:
  • Confirm TPMS sensors are properly installed
  • Adjust tire pressures to placard value
  • Apply parking brake
  • Turn vehicle to ON/RUN
  • Scroll the uplevel on the right side of the steering wheel unit Tire Pressure is displayed
    • This option now shows “Start Vehicle to View Application” and cannot scroll to the tire pressure screen.
  • Push and hold the Set/Reset button
  • Horn will chirp twice, DIC displays TIRE LEARNING ACTIVE
  • Use the tool to activate the left front sensor
  • Single horn sounds
  • Repeat for the RF/RR/LR sensors
  • Horn chirps twice to complete the relearn
I think you can do this while in "maintenance mode" with the truck NOT running.  Hold the start button for about 10-seconds (no brake), and it turns everything on as if it is running.
