- 0
oil pressure drops
Similar Content
- 2 replies
- 5,344 views
- 3 replies
- 8,644 views
- 0 replies
- 2,983 views
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 19 Members, 0 Anonymous, 2,212 Guests (See full list)
Question
Kenneth Walker
2007 suburban 5.3 AFM delete already done. I had one lifter collapse and did the delete now when cold I have 35 P.S.I. but when hot with 5w30 oil pressure drops to 5 P.S.I. I've replaced rods and mains cam bearing's, put the lingenfelter rivets in the towers, replaced the pump 3 times, changed the cam retainer plate, oil pressure switch, different oil filters multiple times. I turned up the idle when in gear to keep the oil pressure at 10 P.S.I. when idling. now to keep the oil pressure around 35 when cruising I'm running 15W40 I know that is some thick oil for the truck but it's either that or I get a range performance code for oil pressure and yes the oil pressure is correct I have hooked up a manually gauge multiple times. how would I check and see if the towers are leaking internally or if the bar bell is bad it sad for 6 months why I was doing the delete I had to get money together to fix it.
14 answers to this question
