Would someone with 2020+ with cab lights get me measurements possibly??
They line up.  Measurements are different because the front edge of the windshield is curved - therefore the center light measures further from the front edge than the side lights.
3 hours ago, hotairgypsy said:
Sorry i am being a pest but trying to get this accurate so myself and others dont hack up our beautiful trucks...can you get me this measurement...need to make sure it is centered..thanks
I have 8 7/16"
  • 9 months later...
On 4/4/2021 at 10:34 PM, hotairgypsy said:
i bought a 3/4 square punch ...if all goes well i thought of putting a how to together and offering a rental on the tool since it is pricey....might help all of us out in the bigger picture
Was the 3/4" the correct size or is the 22 mm better?
I used the 3/4,  its was a little snug.  I did have to do a little filing.  The hardest one was the center, if you are off a little, that can translate to a big difference from hole position 1,2 or 3.   Take you time an measure, measure, measure.
Back 3/4 inch, as long insert is snug and the tabs lock you should be ok,  you do not want the light to twist.  the center will not have that issue but the end light need to be snug even with the locking spring nut.
    247.7k
    2.6m
    Brent Wylie
    Brent Wylie
  • Who's Online   1 Member, 0 Anonymous, 984 Guests (See full list)
