3.0 Duramax cranks but won’t start
4 minutes ago, Tracy Lawrence said:
Yes, I had ran into this you a couple of times. I think in my case it was because I was tapping the starter button and not holding it in for a second. After I started pushing the starter button and holding it for a second or so the problem has not existed since. Hopefully that will be the problem.
A lot of people speculated that it was something to do with brake application while pushing the start button and that has proven to be nothing but pure speculation, the trucks will do the crank/no start with the remotes and you not even being in the vehicle. There’s a fix I’m sure GM just doesn’t have it yet. This problem made the Fast Lane Web forum a few days back so like I said, it’s widespread.
https://tfltruck.com/2021/06/ask-tfl-help-my-new-2021-gmc-sierra-1500-diesel-is-having-start-up-problems-possible-solutions/
Having the same problem here with my 2021 GMC Sierra with the 3.0L. Mine has only done it once so far and it was right at the 2000 mile mark. I took it to the dealer and they could not get the issue to recreate. They then did the “ECM reprogramming for crank no start or extended crank condition.” Which I think is the Technical Service Bulletin: #20-NA-218 from GM. But this was for the 19&20 model sierras. Nothing mentioned about 21s. So I don’t think this is the fix to the problem we are all having.
I just had the same problem. Only 80 miles on it. And I only put 30. The question we should be asking is why would the trigger Wheel bend? And what is stopping if from happing again? Seeing the amount of work to fix it I'm going to ask them to cover all related items until 45k. (That is when my lease is up lol.)
Based on all the trucks that have been inspected the trigger wheel has not been bent on a single other truck, just on the first one they looked at, it was a fluke that they created. TSB off of. Don’t worry about the trigger wheel on your motor.
Got my truck back from the dealer; 2nd time for the no starting issue--starter runs for 15-20 seconds, truck does not start.  Dealer checked fuel injector data, fuel pump high and low side PSI while attempting to duplicate.  Checked and re-tightened ground connections @ G130, 131, 132, 133 and 134. Checked fuel PSI regulator for loose pins. Checked fuel injector #1 and cam sensor. OK no problem found.  So, I do not think the service manager was convinced the issue is fixed, time will tell.  But if it goes in for the 3rd time...?  Total days in the shop-19 days; 3 days 1st visit, 16 for the 2nd visit.
Did they perform the inspection on the reluctor wheel per the Bulletin for this problem?
I bet it’s a bad ground somewhere.
k2xx had one on the driver side A pillar. A manufacturing flaw caused some trucks to have the plastic trim sandwiched under the ground bolt. Caused some weird ass intermittent problems, like the stabilitrack randomly intervening and jerking the wheel. Also would explain why it hasn’t been found yet.
    247.7k
    2.6m
    Joe Upton
    Joe Upton
  • Who's Online   5 Members, 0 Anonymous, 1,040 Guests (See full list)
