Transmission type for 2500 HD 4x4 8.1 gas
I recently purchased a 2001 2500 HD 4x4 with the 8.1 gas engine. While greasing the driveshaft, I noticed a spin on filter for the transmission and the words Alison on the tyranny pan.. It's a 4 speed automatic.. I thought Alison transmissions were either 5 or 6 speed.
Which model Alison transmission do I have?
The Allison 1000 is a 5 speed transmission in 2001.
The 4L80e is a 4 speed transmission but those obviously won't say Allison on it and they don't have external transmission filters.
So which transmission do I have? The shifter has the standard PRND321, and I have a tow/haul mode button on the end of the shifter. Is it a 5 speed, but I'm only using 4? I'll test drive it later and verify the shifts.
The 5-speed Allison has PRND321 on the shifter.  Press/hold the T/H button for a few seconds and you should get a D-with-slash on the cluster display, aka overdrive lockout.  Press/hold the T/H button for a few seconds to re-engage 5th.  They used this instead of a "4" on the shifter.
When you count shifts it may feel like it's a 6-speed, but one of them is the torque converter locking up.
Thanks for the info. As you said, it's a 5-speed. I have 4 upshifts, at 2500 rpm, and then the torque convertor lockup. So it is the Alison 5-speed. I'll play around with the T/H mode to get familiar with that function.
