Diesel and Torque Pro
gemarsh
Anyone running torque pro on a diesel and is watching def usage?? If so, can you explain to a English standard guy what this g/km equivalent would be for def?
There is no way it's using 1.8 gallons per kilometer.
I have the app set to English units, but this gauge is still reading in the metric system.
Haven’t used it yet but willing to give it a try! I have a WiFi obd2 interface just sitting her. I’ll plug it in and see what it reports for me.
2 hours ago, dram1983361 said:
Grams per kilometer possibly
Huh, very well could be. Grams is a weight, correct? Doing math, looks like there is 3765 grams in a gallon. Beings there is still 3/4 tank of def left and almost 3000 miles on the truck,  it very much could be grams.
I think you're right.  Saw this...each US gallon (3.785 litres) of the fluid will weigh 9.2 lbs (4.17 kilograms) or 4170 grams.  Then found this:
Specific Gravity: 9.1 (32.5%) or 9.4 (40%) lb/gal @ 60°F (1.09 – 1.13 g/cc)
This seems more accurate so lets use this:
5.3 Gallons is 21876.76 grams
Divide by 1.8 (your current useage)= 12,153.76 km
12153.76/1.609=rounds to 7554 miles
But that's draining to empty.
Based on your consumption rate of 1.8g/km that works out to .7 gallons remaining at 1000 miles and .21 gallons remaining at 300 miles.
Also that consumption rate looks like it's based off that ignition/drive cycle only and is not indicative of your cumulative consumption.
https://www.trucknews.com/features/diesel-exhaust-fluid-def-facts-unveiled-at-tmc/
  • 4 weeks later...
So the Torque Lite App.  Where all of those settings or monitors pre-programmed in there?  I ran into a guy who was telling me he had to download some PID's I think he called them. Id basically love to know when the truck is about to go into regen so I Can keep driving through it and not stopping half way through.
