2021 trucks with trailering package come with side view camera in use when backing trailer?
And Im wondering if there is a way to make this work on my 2020 AT4? It gives you the side view from under the mirrors like when towing and you put your turn signal on, only this does it when you put it in reverse with a trailer hooked up.
Its not the same down view for seeing the curb/front wheel/back wheel when parking, this one looks rearward.
Sure would help when backing the trailer and should simply be a software fix.
Anyone know if this is possible?
Edited by RaisedByWolves
On 12/30/2020 at 6:10 PM, AdamAT4 said:
My 20 does that and has for almost a year... I just realized in a few weeks my truck is 1
Sent from my SM-N975W using Tapatalk
Do you need to have your signal on for this to work?
Ive tried both ways and nothing.
The article I read said it was new for 2021.
Soon as I hit the signal.. I also have my AT4 with every possible option. The ram and Ford can measure your trailer as well, I think this option is available on the 21s now. I just get the camera focused on my trailer, and I really like it. Haven't had a 8.5 width trailer hooked up yet but it all works beautifully on a 6 wide.
I have a 2020 AT4 Carbon Pro with tow mirrors - camera down the side works when I am towing only (trailer plug trips it).   I read on 2021 it may also work without trailer - which would be nice - as you can see great down side of trailer.  I have 24' that is 8'6" (102") wide and it makes a huge difference in visibility - when turn signal is selected, you just see that see that side on the entire screen.
