2019 Chevrolet trail boss 1.5” leveling kit can I run 35x12.50??
short answer , NO.  the width is going to be he issue. the sidewall will come in contact with with the upper control arm with a 12.50 wide tire. A 35 will fit but try and run a narrower tire so you dont have to run wheel spacers .
I don’t see how they wouldn’t rub against the UCA. I’ve got 35x12.50s but I went with a different wheel with a 0 offset and 4.75 backspace and have tons of room width wise. Front to back I had to cut some ****** and do the mud flap mod. Only rub I have is at lock on the brakes over a bump. I’ve only got a 2.25” lift on the front and rear. I would be skeptical of somebody saying TB/AT4 with a 1.5” level stock wheel no rub on a UCA without seeing the pic of the UCA and the 35x12.50.
1 hour ago, MgoBlue said:
35 12.5 18 bfg ko2 on stock trail boss wheels. Removed the mudflap bracket added Bilstein 5100s and set back to the stock height. No rub at full lock.
Nice. I’ve got a gmc so the rub is because of the square fender wells. Surprised they clear the UCA. I could barely fit my finger between the UCA before I swapped wheels and tires. I don’t have an AT4 tho. So maybe those wheels have a different offset?
