10 hours ago, KARNUT said:
So, the computer is trying to anticipate what your intentions are? ( In the old days) my on board computer would manually down shift if needed. Usually the computer is trying to up shift as fast as possible for fuel mileage. As far as possible bad valve springs. Just drive. If they break get them replaced. That’s probably just too obvious.
Yea that’s ok lol if your under warranty and don’t have a problem waiting at dealership for them to replace the spring or a new motor. Or better yet it does it when your just off warranty spring breaks valve drops into cylinder. Then you got big $ problems. Hope that doesn’t happen to anyone. Also I do agree with you it seemed older programming would upshift quicker when you let off to achieve better gas mileage and that would be annoying if it was to quickly too. So from what I’ve read just be happy with way my truck is and enjoy it because if updated could only make things worse possibly.
Edited by bjr2020 6.2
Picked up my 21 TB with the 6.2 last monday...drove it home. 3 days later at 240 miles the valve spring broke.  The local dealership fixed it very quickly but needless to say I was a tad bit upset. Hopefully that's all that happens.
Mines been rock solid so far. 7/2020 build I was hoping gm had this worked out by now too. It’s the vendors I think that are providing the part I’m thinking are subpar. I think ? I read or heard that gm replaces the whole bank on the side that broke.
36 minutes ago, BlaineBug said:
L83 5.3 not affected, I'm relaxed.
Is that what the 5.3 is? L83?  What is the L-82, L-84 and L8T?
Isn't the L-82 5.3 in the trucks now?
https://gmauthority.com/blog/gm/gm-engines/l82/
Or is the L-84 5.3 in the trucks now?
https://gmauthority.com/blog/gm/gm-engines/l84/
Edited by steelcity
I'm not sure.  I just checked my build sheet.  Although I knew in the past it was mainly the 6.2s that were experiencing valve spring issues.  But I hadn't saw the specific RPO codes listed until now.
Actually I just searched really quick, the L-82 AND L-84 appear to be newer than the L-83 and both are 5.3  However the L-82 was put into the 2019+ Silverado, Sierra.  Perhaps 2020+ Yukon, Tahoe, Suburban since they share the same redesign styling too?  Also it seems as though the L-82 has active fuel management and L-84 has dynamic fuel management, which is capable of operating on only 2 cylinders.  Active fuel management only switched between 4 and 8, or 4 and 6 if you had a V6 4.3 liter.
L-83 was the 5.3 used pre-2019 for trucks and pre-2020 for SUVs.
The L8T is a 6.6 liter.
Edited by BlaineBug
4 minutes ago, BlaineBug said:
Actually I just searched really quick, the L-82 AND L-84 appears to be "newer" than the L-83 and both are 5.3  However the L-82 was put into the 2019+ Silverado, Sierra.  Perhaps 2020+ Yukon, Tahoe, Suburban since they share the same redesign styling too?
So what 5.3 is in the 19/20 Silverado?Sierra now? I'm really confused now, lol
I think it is the L-84
https://www.onallcylinders.com/2019/07/25/l84-5-3l-ecotec3-engine-specs-performance-bore-stroke-cylinder-heads-cam-specs-more/
Edited by steelcity
I'm sorry for the garbled information.
The L-82 5.3 was used in the 2019+ Silverado and Sierra with the 8 speed transmission and active fuel management.
The L-84 5.3 was used in the 2019+ Silverado and Sierra with 10 speed transmission and dynamic fuel management.
It would be my best guess that the L84 5.3 is the engine used in 2020+ Yukon, Tahoe, and Suburban.
Edited by BlaineBug
The L-82 5.3 was used in 2019+ Silverado and Sierra with the 8 speed transmission and active fuel management.
I have a 5.3 with 10 speed so I guess mine is a L-84. And it was built right in the middle of the dates reported
Mine is a 2020  Sierra AT4
Edited by steelcity
According to GM Authority you should based on their application chart.
Dynamic fuel management has 17 cylinder patterns whereas active fuel management has 2.  DFM operates on less than 8 cylinders 9% more often than AFM according to their press release from May of 2018.
5.3 L82 https://gmauthority.com/blog/gm/gm-engines/l82/ (6 speed transmission, active fuel management.)
5.3 L83 https://gmauthority.com/blog/gm/gm-engines/l83/ (8 speed transmission, dynamic fuel management.)
5.3 L84 https://gmauthority.com/blog/gm/gm-engines/l84/ (8 speed transmission, dynamic fuel management.)
6.2 L87 https://gmauthority.com/blog/gm/gm-engines/l87/ (10 speed, dynamic fuel management.)
Application tab is there to check years and models.
PS - Any 2019+ Silverado and Sierra with a 6 speed transmission will have the L82 engine also, according to GM Authority.  It's odd that their application list doesn't include prior years.
Edited by BlaineBug
5.3 L84 https://gmauthority.com/blog/gm/gm-engines/l84/ (10 speed transmission, dynamic fuel management.)
I clicked on the application tabs for the L-84 and it doesn't even list the 10 speed, just 8 speed, lol.
I have to have the L-84 though, thanx!
