Dome light fuse
28 minutes ago, Cheverado said:
2014 1500 LTZ Z71. Dome lights quit working. I can’t find the fuse. Help plz
Make sure it's not the overhead switch. It has an OFF setting that can be pushed accidentally.
https://youtu.be/uW4NHaN4iZo
Edited by rav3
13 minutes ago, Cheverado said:
Tried that. Lights over rear seats don’t work either
https://fuse-box.info/gmc/gmc-sierra-mk4-2014-2018-fuses-and-relay
IIRC, that switch controls both, at least it does on mine, Double cab.
Edited by rav3
I worry it might be internal to the BCM under the dashboard. Did you try to pull the battery and reset the computer for a few minutes and try again? I can try to pull down my shut off switch in the overhead compartment to see if when disconnected it will allow the lights to turn on.
