Matt Castro Posted November 12, 2020 Share Posted November 12, 2020 I had my truck lifted about 2 years now and just started noticing a vibration bad. So I did what anyone else would do and jump on google and YouTube. So after replacing my upper control arms and ball joints then my lower as well I still have a shake can someone help I’m at this point desperate Quote Link to comment Share on other sites More sharing options...
Stevenmorris.us Posted November 12, 2020 Share Posted November 12, 2020 What year is your truck, this plays a role in where to address Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Matt Castro Posted November 12, 2020 Author Share Posted November 12, 2020 2017 GMC Sierra 1500 Quote Link to comment Share on other sites More sharing options...
CamGTP Posted November 12, 2020 Share Posted November 12, 2020 And you've done the normal things like check tire balance and road force on the tires?? Other things to consider on cv axles and driveshafts causing a vibration. Quote Link to comment Share on other sites More sharing options...
Matt Castro Posted November 12, 2020 Author Share Posted November 12, 2020 Yes I switched out tires from my Yukon and put them on and same thing I have the vibration check balance on them as well I have replaced upper and lower control arms and ball joints I have a bit of play in the front drive shaft where the yolk is but not to sure if it’s supposed to be like that with a lift Quote Link to comment Share on other sites More sharing options...
Snowcamo Posted November 12, 2020 Share Posted November 12, 2020 Have your hubs checked. That might be it. Quote Link to comment Share on other sites More sharing options...
Matt Castro Posted November 12, 2020 Author Share Posted November 12, 2020 Thanks that is one thing I haven’t done is the rear. Thanks I may mess with it tomorrow hopefully that’s the issue cause this shake is over the top already Quote Link to comment Share on other sites More sharing options...
HOGNATION_64 Posted November 12, 2020 Share Posted November 12, 2020 Google "Chevy Shake", I have a 2018 Chevrolet Silverado LTZ 4x4 and it happened to me. There is a bulletin out on it for 2014-2018 models. They will start with flushing out the transmission and if that doesn't work then they will work thru to the converter/transmission. They say it could be the fluid used in it. They flushed mine and I've put about 5k on it and haven't had any issues since. If i remember when i get to truck I'll send you the bulletin number. Quote Link to comment Share on other sites More sharing options...
Matt Castro Posted November 12, 2020 Author Share Posted November 12, 2020 45 minutes ago, HOGNATION_64 said: Google "Chevy Shake", I have a 2018 Chevrolet Silverado LTZ 4x4 and it happened to me. There is a bulletin out on it for 2014-2018 models. They will start with flushing out the transmission and if that doesn't work then they will work thru to the converter/transmission. They say it could be the fluid used in it. They flushed mine and I've put about 5k on it and haven't had any issues since. If i remember when i get to truck I'll send you the bulletin number. Thank you I’d appreciate that Quote Link to comment Share on other sites More sharing options...
Snowcamo Posted November 12, 2020 Share Posted November 12, 2020 Thanks that is one thing I haven’t done is the rear. Thanks I may mess with it tomorrow hopefully that’s the issue cause this shake is over the top already Yea bud I go a buddy who just lost a 14 wide on the hwy... I always told him as a good practice swap the hubs once a year or so. He said his didn't even have any play. I told him... Well I told him... And he was approximately 2yr in on his. Just a pic for reference. Sent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Matt Castro Posted November 12, 2020 Author Share Posted November 12, 2020 Ain’t much play in front it’s more of the rear now and as I’m driving I look at the tires through the mirror and I see some play like the tire is bouncing Quote Link to comment Share on other sites More sharing options...
Snowcamo Posted November 12, 2020 Share Posted November 12, 2020 Rear shocks or tire needs a true road force balance. I see this every day here in texas. Which if your in DFW i can recommend the only shop across dfw that was able to balance mine. Quote Link to comment Share on other sites More sharing options...
Matt Castro Posted November 12, 2020 Author Share Posted November 12, 2020 I’m in corpus but I will definitely look at the shocks. Could it be possible that they are extended to its max Quote Link to comment Share on other sites More sharing options...
Snowcamo Posted November 12, 2020 Share Posted November 12, 2020 Yes that is very well it as shocks don't tend to do well when they are maxed out. Sent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Matt Castro Posted November 12, 2020 Author Share Posted November 12, 2020 Definitely checking as soon as I get home Quote Link to comment Share on other sites More sharing options...
