Who is running 22" Wheels? Step in please!
18 minutes ago, firedab said:
Yup, those are the wheel and tire specs, and no leveling kit, but I did turn the keys (bolts) two turns, have about an inch difference between front and rear. I’m going to work on mud flaps tomorrow, I’ll post when I get them done.
How does it ride?
Did you buy a bumper spacing kit or do a DIY?
Ride is similar, you can feel the bumps a bit more, nothing crazy. Not much louder with the Nittos either. I did the DIY route, may change them out for the actual kit, but it works...
So I bought the wider OEM mudflats and they are actually 2 pieces in the front. I took them apart and heated up the edge and folded it a bit to make it look better. So far so good, does not appear to be rubbing.IMG_5346.thumb.jpeg.5143f38f928f28f73971dbbb30b696da.jpeg
Can you give me the part number for those?
thanks
  • 4 weeks later...
can you post pics slightly further out from the truck?
would like to see how the entire flap looks
thanks
  • 1 month later...
