Center screen too bright in reverse at night
rav3
Is there anyway to change the settings on the center information screen when backing up at night? My '17 LTZ screen is blinding to the eye when backing up at night. Even in the daytime, the colors are distorted due to the brightness. Have I missed an adjustable setting somewhere?
2 minutes ago, GOMD said:
There was a service bulletin for this, make an appointment for the dealer to flash the software.
https://static.nhtsa.gov/odi/tsbs/2018/MC-10137570-9999.pdf
Thanks much. I wasn't aware of this. My truck in a '17 that I bought in Feb of this year as a Certified Truck, so should be covered under warranty. I'll ask that this be done at next oil change service.
Thanks again. I'll print this out for the service writer.....
That helped on mine, but VERY LITTLE.  There is a pin that you need to pull from the back of the unit.
Thanks! Very helpful. I found this video on removing the unit as you described in the above link
2014 Silverado Screen Removal
