Trans thermostat part number?
After contemplating this mod for a coupla years now, finally did it this morning. It went pretty smooth, no corrosion to deal with but getting the circlip out gave me a bit of a challenge, 5 different sets of circlip pliers and none of them would grab worth a darn, maybe the holes are metric sized...Didnt have an issue putting it back in place tho.
I have the plate style holding the trans lines. Beware the two o-rings on each line, one stayed in the block when I removed it, just watch you dont lose either. 10 and 13mm ratchet wrenches to remove, added a 10mm stubby ratchet wrench when installing due to exhaust pipe.
I did some test runs afterwards with "4 stop and look for leaks", quite happy with the results.
22 minutes ago, lovecars said:
Excuse my ignorance,  is there a performance betterment in changing this thermostat?
Or is it a part that needs watching out for?
Thanks
My take on it is: It reduces the higher running temperatures that the transmission see's by about 30 to 50 deg F. Transmission (fluid) & transmission seals degrade faster at higher temperatures, so should allow stuff to live longer, than at the 185 to 200 deg F.
  • Thanks 1
On 10/14/2020 at 12:24 PM, It's Tim said:
If the OP destroys the original trying to "fix" it he'll really be without a paddle. (or a truck for that matter too.)
Negative
i drove for 15k miles with a stuck closed trans thermostat
it was stuck from the factory, i didn’t know I had a problem with it for a long time
