Plowing with a 1.8 yard spreader?
That’s why I been hearing , I currently have a 8’ western pro plus steel plow and western 1.8 spreader. I wanted to go gas to get away from the constant diesel issues but I guess I’ll have to buy diesel again...
Typically the difference between the FGAWR and the existing weight on the front axle when you have a gas engine is bigger compared to a diesel.  Basically you have less weight to start with so you have more room for the plow.  If anything else it means less wear and tear on the front end components. I live In Vermont and everyone around here plows. The overwhelming majority plow with a gas truck.  Lower initial cost, lower cost to operate and less room for potential problems. I dont think you'll have any issues with the 6.6 gas and it'll probably cost you less in the long run.
