Linecapt Posted September 3, 2020 Share Posted September 3, 2020 (edited) I got a letter in the mail today from GMC regarding my 2016 Sierra with the 6.2L engine that "may have a condition that affects the electrical connection to the transmission oil temperature sensor. If this condition occurs, rough transmission shifts or hesitation during acceleration may occur. Additionally, the Malfunction Indicator Light (Check Engine Light) would illuminate and a diagnostic trouble code related to the temperature sensor would set." They're extending protection to 10 years or 120000 miles. Has anyone else with the 6.2L engine received this letter? Does anyone think this relates to what everyone always complained about, the rough shifts and the hesitations that we've long complained of? Edited September 3, 2020 by Linecapt Quote Link to comment Share on other sites More sharing options...
M1ck3y Posted September 5, 2020 Share Posted September 5, 2020 lol, don't all of the transmissions do this? Of course that is if you drive your truck, and don't let your truck drive you. Quote Link to comment Share on other sites More sharing options...
mookdoc6 Posted September 5, 2020 Share Posted September 5, 2020 On 9/2/2020 at 6:09 PM, Linecapt said: I got a letter in the mail today from GMC regarding my 2016 Sierra with the 6.2L engine that "may have a condition that affects the electrical connection to the transmission oil temperature sensor. If this condition occurs, rough transmission shifts or hesitation during acceleration may occur. Additionally, the Malfunction Indicator Light (Check Engine Light) would illuminate and a diagnostic trouble code related to the temperature sensor would set." They're extending protection to 10 years or 120000 miles. Has anyone else with the 6.2L engine received this letter? Does anyone think this relates to what everyone always complained about, the rough shifts and the hesitations that we've long complained of? I have surmised that from the beginning the junk wiring harnesses on 2015-2016 on 5.3/6.2 8L90 Transmissions along with the super fancy 6 pin MAF sensors that are so sensitive to Dry,Humid air and their corresponding densities and temperatures.....Got a Crap 8L90? Drive it in the rain and report back....Yeah, it's coupled with Hygroscopic oil which amplified the drive-ability issues. GM can't figure out what day the trans drives better astonishing.....but hey? nobody listens to me.................... Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted September 5, 2020 Share Posted September 5, 2020 5 minutes ago, mookdoc6 said: I have surmised that from the beginning the junk wiring harnesses on 2015-2016 on 5.3/6.2 8L90 Transmissions along with the super fancy 6 pin MAF sensors that are so sensitive to Dry,Humid air and their corresponding densities and temperatures.....Got a Crap 8L90? Drive it in the rain and report back....Yeah, it's coupled with Hygroscopic oil which amplified the drive-ability issues. GM can't figure out what day the trans drives better astonishing.....but hey? nobody listens to me.................... You sound like my dad. His favorite is, "But hey don't listen to me, I'm just a dummy". You two should meet. 1 Quote Link to comment Share on other sites More sharing options...
martha3065 Posted September 5, 2020 Share Posted September 5, 2020 Does anyone think this relates to what everyone always complained about, the rough shifts and the hesitations that we've long complained of? I doubt it is the cause of all the complaints. Mine has had those symptoms since nearly new, as does a buddy's. Probably gets worse under this condition. I do think this is the same issue members have posted on here: https://www.gm-trucks.com/forums/index.php?/topic/224729-Money-Light-on-8-Speed,-P0700+P0711 Quote Link to comment Share on other sites More sharing options...
Ltz4 me? Posted September 6, 2020 Share Posted September 6, 2020 Mine was just fixed b/c of this code on a 16' Silverado 5.3l 8speed m5u tranny. While the pan was dropped I had them completely drain all bad fluid completely, new tranny filter, new best blue label Mobil 1, new 2 piece wiring harness, transmission relearn. We will see...it did start shifting really.bad when check engine light came on,( po711) Transmission temperature sensor was verify ok by the ohm reading taken. If I can I'm flipping my pill to reduce the oil temperature ( I'm regularly seeing 185-195deg.f) Quote Link to comment Share on other sites More sharing options...
Z45 Posted September 6, 2020 Share Posted September 6, 2020 185-195ºF is NORMAL operating temp for an automatic transmission. It runs at peak efficiency at those temps as its DESIGNED to do. I don't understand why people fell this is bad, its not. Its paranoia. 1 Quote Link to comment Share on other sites More sharing options...
mookdoc6 Posted September 8, 2020 Share Posted September 8, 2020 On 9/4/2020 at 8:10 PM, Grumpy Bear said: You sound like my dad. His favorite is, "But hey don't listen to me, I'm just a dummy". You two should meet. Your pops is probably pretty neat guy and holding up well at his age. Most of my knowledge base is from people of that generation...I reckon there is not much of substance I have learned from the younger folks. they can put an "APP" on my phone but that's about all............... 1 1 Quote Link to comment Share on other sites More sharing options...
CadillacLuke24 Posted September 13, 2020 Share Posted September 13, 2020 On 9/5/2020 at 7:05 PM, Ltz4 me? said: Mine was just fixed b/c of this code on a 16' Silverado 5.3l 8speed m5u tranny. While the pan was dropped I had them completely drain all bad fluid completely, new tranny filter, new best blue label Mobil 1, new 2 piece wiring harness, transmission relearn. We will see...it did start shifting really.bad when check engine light came on,( po711) Transmission temperature sensor was verify ok by the ohm reading taken. If I can I'm flipping my pill to reduce the oil temperature ( I'm regularly seeing 185-195deg.f) Do you have a part number for the new 2-piece wiring harness? Quote Link to comment Share on other sites More sharing options...
midwestdenaliguy Posted September 15, 2020 Share Posted September 15, 2020 On 9/13/2020 at 5:17 AM, CadillacLuke24 said: Do you have a part number for the new 2-piece wiring harness? Just posted the details of the special coverage that extends the warranty on this issue. Includes part # for harness: Quote Link to comment Share on other sites More sharing options...
STurner15 Posted September 16, 2020 Share Posted September 16, 2020 Got my letter in the mail and took it in immediately. 74k miles 6.2L. They flush the trans with new fluid and replace seals etc etc. have about 20-30miles on the truck now and it seems to run better. But I got a flush around 65k and it worked for a little while... so I am hoping this harness and flush works.... for a .. little while.... longer... Quote Link to comment Share on other sites More sharing options...
flyingfool Posted September 25, 2020 Share Posted September 25, 2020 On 9/6/2020 at 3:23 AM, elcamino said: 185-195ºF is NORMAL operating temp for an automatic transmission. It runs at peak efficiency at those temps as its DESIGNED to do. I don't understand why people fell this is bad, its not. Its paranoia. sure, back when a transmission was all mechanical, they could take the heat... but now they put delicate plastics, seals, platic check balls and a tcu in the hot boiling transpan.. yeah that will make it reliable, sure! Quote Link to comment Share on other sites More sharing options...
STurner15 Posted October 30, 2020 Share Posted October 30, 2020 so far so good on my end. added a couple pounds to low end gears shift pressures. smooth and solid still. Quote Link to comment Share on other sites More sharing options...
lucas287 Posted October 31, 2020 Share Posted October 31, 2020 On 10/30/2020 at 9:24 AM, STurner15 said: so far so good on my end. added a couple pounds to low end gears shift pressures. smooth and solid still. Did you do this in HPtuners? If so what table(s) did you change? I'm always tinkering here and there with my tune. Quote Link to comment Share on other sites More sharing options...
STurner15 Posted November 9, 2020 Share Posted November 9, 2020 I just used my Diablo tuner. gears 1->2, and 2->3 I added +3 to the shift pressures. Quote Link to comment Share on other sites More sharing options...
