  • Sign Up
  • 0
Need help with possible electrical hookup
Dazedswift
Question
Hello! To whomever may have any advice. I recently bought a 2005 gmc single cab with a 6.0 4l80e that wouldn’t start unless you put a little fuel down the intake and jump the starter(which I didn’t do bc I’d rather fix the problem logically). Anyways so a problem that I found is that he had actually broken the ignition interlock cable on the steering column and you were actually able to turn the key by hand but turning it to the start position wouldn’t do anything other than a like if you would say meh out loud that’s literally what the engine or I believe the electrical would sound like when you turned the key into that position. So I replaced the wire from a donor steering column which was a PAIN!!! anyways I have the original column in with the new wire but it’s still not trying to start at all. I also noticed that the throttle body doesn’t open when you press the Gas and you can’t push it open. It also makes a small humming noise like it wants to try to open and slightly vibrates. Also so I jumped the 87 pin on the starter relay to the positive and the engine turns over but won’t fire and start. I’m assuming that it’s a fuel problem(yes I put fuel in the tank today 7gals). So my next theory is going to maybe test the starter? I’m not really educated on this stuff but I do have the tools for the most part. Any advice would be appreciated. ALSO it has a newer ignition Solenoid and it has the lock and car light on the dash so I’m not sure if the new keys have to be programmed and that has anything to do with it? Maybe? But I’m not sure and thank you again! I’ll post a link to a YouTube video tomorrow to show exactly what’s going on and what I’m working with for a visual!
1 answer to this question
  • 0
You need to test and see what you have and what you don't. Fuel pressure, injector pulse, spark, etc...
Answer this question...
