Longer Rear U-bolts?
Where would I get longer rear u-bolts for my rear suspension? I'm thinking about replacing the 2 inch rear lift block with a 3 inch block, but I'm not sure where I would find longer u-bolts that will be shaped like the factory ones. They are not rounded on the closed end, but more suare shaped.
Thanks for any tips. :thumbs:
If you get a 3" block kit, it will come with the blocks and U-bolts. If you need just the U-bolts.......go to any farm supply or auto parts store. They have them!
Ah, that makes it easy. :puke:
For some reason, I thought they didn't come with u-bolts. Maybe it's the non-vehicle specific blocks don't come with them.
Thanks for the info all. :thumbs:
Here's another question. Will the stock Z71 shocks be too short to use with a 3 inch rear block (vs the factory 2 inch block) and ford torsion bar keys in the front?
I didn't think about the shocks being too short. :puke:
BTW, I called Superlift and they said thier vehicle specific kits DO come with u-bolts, washers, and nuts. :thumbs:
Hmm :puke: Even if I only plan on trying to get only an inch, maybe 1 1/2, lift out of the front?
I'm thinking if I have to change the fronts, I'll more than likely change the rears too at the same time, which leads to yet another question. :lol:
What is a good choice for a longer shock, and yhow do you explain to someome you need a shock that is longer than the stock ones (and have them understand you and get it right)?
Thanks for all the info. :thumbs:
Ok, if you go only 1-1.5 inches. You will be fine. Anything over that.......you may want longer shocks. Pretty much, all manufactureres will say that their shocks are for xxxxx amount of lift. So if you add 2-3 of lift. You need that kind of shock. Almost every manufacturer makes longer than stock shocks. Anywhere form 2-10 inches of lift. 4 Wheel Parts can get you what you need.
  • 2 months later...
Most drivetrain shops (driveshaft, gear and axle specialists) have the equipment to make them. 4 wheel parts referred me to one a 1/4 mile down the road, when they found that they didn't have any long enough for my dually and a 5 inch block. I had to have 19" ubolts custom made, but here's the kicker...they were less expensive than the ones that 4 wheel parts wanted for theirs. It was a simple in and out procedure, took about 3 mins if that.
If you're in Dallas Fort Worth (Texas) area, I can give you a set of U bolts with 4" blocks for free. When I had my Procomp Suspension adjusted at 4 Wheel Parts, they changed these 4" ones to 5.5" blocks and longer U bolts. So I asked them to give me the 4" in case I decide to lower my trucks ride height, which I won't do.
