- 0
06 Sierra ac cycling issue
Similar Content
HELP! For the time being WAMS is not doing BCM programming to retro fit OEM ventilated seats!!
By Jgrazy22,
- 2 replies
- 296 views
- 0 replies
- 227 views
- 2 replies
- 4,057 views
2021 RST with the Silverado Shudder
By GarandPappy,
- Torque Converter
- Transmission Fluid Flush
- (and 3 more)
- 1 reply
- 595 views
- 1 answer
- 391 views
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 17 Members, 2 Anonymous, 2,337 Guests (See full list)
Question
FF259
I have a 2006 GMC Sierra 1500 4x4. A/c has been out for over 2 years had a bad compressor never got around to fixing it. Today I replaced the compressor, condenser, accumulator, orifice tube, and flushed all lines. Took it up to my buddy at the dealership and we charged it up. Put it under vacuum for a bit and no leaks. Drove home about 12 miles no problems blew ice cold. Left to go to the store about 2 hours later started it up the ac button was on but clutch wasn’t engaged and ac blowing warm. Turned the button off then back on clutch engaged and blew ice cold. About 10-15 seconds clutch disengages blows hot cycle the button again blows cold again. Every 10 seconds or so it blows hot and I have to cycle the ac button on the dash again get cold air.
I know the compressor clutch should cycle on and off that’s normal but I don’t think it should be that frequent and you shouldn’t feel that significant of a temperature change right? And when it cycles off it doesn’t come back on unless you cycle the button.
I’m thinking a issue with the low pressure switch on the accumulator but any advice?
Edited by FF259More info
9 answers to this question
